2014 Ram Quad Cab Speaker Upgrades
  • 2
muddycb
As the title states, I am looking to upgrade my speakers in my Ram. For now I will be running the speakers off the head unit with the possibility of amping them down the road. I will be adding a 10" sub as well as adding sound deadening material to the doors and rear panel.
Font Dash:
JL C2-350x 3.5's with built in crossovers
Front Doors:
6.5 Mid Bass drivers. Haven't decided on a brand (suggestions?). Also it appears that my system only sends midbass frequencies to this speakers now. Otherwise I can use some sort of a passive crossover/amp them.
Rear Doors:
JL C2-650x 6.5's with built in crossovers
For soundstage/imaging purposes I feel like this is the best way to go. However, another option would be to run a set of components in the front with the tweeters in the dash. Let me know what you guys think or suggestions you have for another setup. Let me know if I need to provide additional information. Thanks again in advance.
Daniel
In a newer vehicle speakers alone are not my first recommendation for an audio upgrade. You're likely to be disappointed because of the inability to tune the system to your liking and a lack of power to the new speakers. I would keep it to 6x9s in the doors and add a 4-channel amplifier before spending the money on a subwoofer upgrade. I could put together a package for you if you'd like.
I was thinking about doing some sort of 5 channel amp with it powering the front and rear doors with the dash running off the head unit, with the last channel pushing the sub. However, it does sound kind of crazy not putting power to the dash speakers so I'm confused on how I would go about powering everything. So Trumpet I'm open for a suggestion on a build.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
801
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
muddycb
muddycb
United States
muddycb
    May 31, 2024
    May 24, 2024
