2014 Mazda 6 with Bose; looking to swap everything out
toolin4
Greetings All!
New member, looking for some quality advice and good guidance on swapping out my entire system (except HU) on my 2014 Mazda 6 w/Bose.
Went to see a local retailer today, who recommended the following:
-JL Audio OEM integration
-Focal PS165F 6" components for the front
-Cheaper Focals for the rears (only every have the kids back there)
-JL Audio HD900 5 channel amp
-JL Audio CP110LG-TW1 in the trunk; running off the JL Audio amp
-deactivate the stock centrechannel
Done some research, and see the recommended components are solid, but at $4,500 ($900 of that installation costs), had a bit of stickershock. (It's worth noting, I am in Canada, so things are a bit more here)
Parts pricing seems reasonable per my research, but $900 seems steep for the install (they priced it at 12 hrs @ $75/hr)
Not an audiophile by any means, but willing to pay for quality, as long as I can hear a difference.
Any suggestions on equally good (or sufficiently good) alternatives to their proposal above that would save me some bucks?
Forever thankful for any suggestions/help anyone can offer
Greetings All!New member, looking for some quality advice and good guidance on swapping out my entire system (except HU) on my 2014 Mazda 6 w/Bose.
I drive a vehicle that has a bose 10 speaker system, to include the center channel, and all I did was add an LOC and amp and subwoofer. If you can do a little research, you can find what you need for much less. Even better if you could get someone from this site to be willing to ship to you if you wouldn't mind buying gently used stock dude. almost 5 g's is way too much.
Do you feel comfortable installing amps and speakers? Let install the integration module then do the rest. Also, we can probably find you something similar to jl minus the big price
I have a '14 Mazda 3 grand touring with the Bose as well. I wired a LOC onto my Bose amp and put in 3 JL Audio 10s. The difference just adding the subwoofer made was leaps and bounds. I also thought the factory sound was weak. Now I'm in no rush to upgrade the doors or center speaker.
Sent from my SM-G935V using Tapatalk
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
743
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
toolin4
toolin4
Waterloo, Canada
Jhicks
    May 19, 2024
    May 19, 2024
