2014 Hyundai Elantra amplifier install
I have the exact same car as you. There are some rubber plugs, but you can also just drill your own hole and then seal it up with some hot glue. Make sure the hole is almost the exact size as your wire.
Rather than glue, I'd recommend a grommet. The hole in the firewall will need to be determined by the grommet size, but I think a grommet is much safer in terms of not shorting out due to vibration.
Have you added or changed your battery yet?
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
977
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
679
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
986
cmdauria
cmdauria
Tampa Florida
Reactions
