2010 Impala Enclosure
Austin.Stott
Looking for a SQ setup with good sound and good thump. Using an Audison Voce 5.1k amplifier
Here are the options I've been presented with so far:
Single JL 12W6, 12W7, Fosgate P3 or Alpine Type R in a trunk box
2 JL 6W3s mounted into the back deck lid in place of the 6x9s with a custom box mounted underneath. I'm most interested in this design because then it gets the sound waves directly into the cabin. Loved the way the bass sounded in my Durango because the waves had so much space to develope which is something you just don't see much in trunk boxes. Has anyone ever seen an install like this in a sedan?
My budget is about $1000 max for the sub and enclosure.
Wanna stick with JL, Alpine or Rockford because that's what my local shop carries.
The goal is to get the best sound inside the cabin . Output isn't as important as I wanting it to sound clean and defined but I want a lot more output than you'd find from a factory Bose woofer. What did you mean by package tray design?
Would you just recommend a normal spec box in the trunk or would you try to port it into the cabin at all? Why would you say to stay away from the package tray design?
thats just a bad design and i wouldnt port into cab ..ive tried it and ubles u seal it off it doesnt sound great and that more of a spl thing .best bet is a songle 12 in a box with subs and port facing the trunk ..and folt the seats dowb when u want extra output...
Austin.Stott
Austin.Stott
Logan, UT
NASTY08IMPALA
