200amp alternator limitations
dmz2711
FL
how much max power can you run off of a 200amp alt? i heard that for every 1000watts of power it takes 70amps from the alt.... But with batteries, i believe you could run more than 2700watts off of a 200amp alt. So in summary how much? 5k, 7k, 10k? if anyone actually runs and has experience with a 200amp alt, what is the most power you ran off of it without dropping your voltage levels a ridiculous amount?
anyone with experience with a 200amp alt, that can chime in, feel free... how many watts max, on music did you run without huge voltage drops???
There are more factors than the alt it's self. Amp e is very important in trying to figure out this. Also, cables, distance, and many other factors apply. But, with a 200 amp alt you should be able to supply enough power for most systems.
thanks, i understand. I'm just wonderin what people with a 200amp alt are actually running on daily music??
depends on the alt too- what does it make at idle?
i'm running only 5k rms off of a 450 amp iraggi with 6 svr 80-12s- could i run that much power with a 200 amp and 1 rear battery? sure, but i wouldn't want to.
****, 450 amp alt??? for what vehicle, and how much was that thing?
alt is "for" a late model 3/4 chevy/h2 etc. i'm not sure what all vehicles- it's a custom iraggi case etc. made to fit some chevy junk
it's in a 1996 explorer
i didn't pay too much
i ran 4k on one daily for a little bit, not too happy at idle, but driving it was perfectly fine, i had a G31 batt in the back
awsome thanks for the response. you think 5k watts with 2 kinetik 2400's in the rear? maybe a yellow top under the hood or maybe a kinetik 1400 under the hood will be possible?...
I run 2 Alpine 605s, Alpine 545 and a Alpine MRV T420 on My 200 amp just fine. I made sure the VR was putting out 14.4 volts at idle.
I did make sure they installed a pulley that would make this happen.
Make sure your wiring and grounds are sized right and you have the right size fuses to match.
dmz2711
dmz2711
FL
Team Hammer
