200A current draw - How big should my fuse be?
But it says I only need 4guage lol and Im not spending more money on wire haha so 4 gauge it is lol what should I do about the fuse then?
I tell you what. Just dont run a fuse so you can burn up the wire and your car. Then when you get a new car you can up your wire size //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
listen to moe and jntar..upgrade your wire ...if u dont want to use 0awg..use atleast 2awg..so u wont burn your wire as quick...slap a 300amp fuse or circut breaker in there if u can
80
You actually don't need that big of a fuse, really. I have had two nine.1's at .5 ohm each on a 150 amp ANL fuse. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's amazing how much ACTUAL current gets drawn compared to what they are rated for. I bet you could easily get away with a 150-200 amp ANL fuse.
And yeah, definitely upgrade your wire. http://www.weldingsupply.com 1/0 wire for $1.30 a foot+shipping.
I have 4 gauge which is what it says it requires. It also says from the BAT to the Fuse Block should be 0 gauge but Im just gonna use 4 for that too.
The amp says it only requiires 4 gauge ran the whole way? Or 4 gauge into the amp?
they assume your distro will be close to your amp. 4 gauge can carry that current over short distances. Besides can you alt even support a 200 amp load? i assume you have another amp AND the other elec accesories on your car. (elec fans, lights, vent blower,.....)
You would need a 300A+ alt to have it done right.
Yea I have a stock alt. And its a Dodge Neon so I thinking its less than a 100A alt. So its gonna blow up then? haha Im thinking I should just resell this cause I got it for dirt cheap but I dunno.
aarunt1
:D
aarunt1
Ridgecrest, CA
aarunt1
