Sold 2007 Memphis 16-MCD1000d amp
lastcall
lastcall
amp is a couple weeks old. this is the 2007 model. black skinny pearl color. been using it for 2 12w6v2s but going a different route. paid $450 at the local dealer, and still have the original receipt and other paper work. mint condition. and has a one year warranty from the dealer. may not be transferrable but if something happens to it you can send it to me and i will get it fixed for you. asking $290 shipped.
Product Description:
Class D Monoblock Subwoofer Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
RCA Outputs: 1 Pair
Gold Plated RCA Connectors
Full MOSFET Design
Built-In Fully Variable Low Pass Filter: 50 - 250 Hz
18dB Per Octave Crossover Slope
Built In Fully Variable Sub-Sonic Filter: 20 - 50 Hz
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
300 watts x 1 chan. @ 4 ohms
600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 ohm
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 15.75" L x 7.6" W x 2.4" H
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts x 1 channel
RMS Power (2 ohms) 600 watts x 1 channel
RMS Power (1 ohm) 1100 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.75%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 250 Hz
Subsonic Filter 20 - 50 Hz
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost N/A
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 40A x 2
lastcall
lastcall
lastcall
League City, Tx
Soundwavedave
