2004 Grand Prix gt build
  • 4
TIG
I have been searching and asking questions for a few weeks and in that length of time I started my build. I ordered my sub and the following 2 days I built the box. I still need to cut out the speaker hold, put the top on and cover in vinyl. I got my speaker also so now Im waiting to buy my amp. Im looking for a nice strong daily system and something I can turn up and get good numbers out of at a comp. Im looking for around 145db+ on 3kw+. I have all but my amp now and I just put a deposit on a hifonics colossus 3200d. I will have my box facing into the car port and sub forward without sealing off the trunk completely. I may eventually do a complete sealed trunk but as of now I have no plans of doing so.
Heres some pics
I will get more pics as I install all the parts. I still need to build an amp rack but thats not going to happen until I get my amp.
SUB is a dc xl 15 and inclosure in 3.8 cubes 35 hrtz on a aq 3500.1 and I have a 200 amp alt and 2 batteries, all 1/0 wire
Havent been on here much but I got some things done. Installed a voltage meter, run all wire and hooked the aq and dc 15 up. I was firing the sub into the cabin and was getting a lot of cancelation so I decided to start sealing off the rear deck and deadening **** so I can get the sound I need. This thing is a beast for sure. Im running on a 100amp anl right now daily with no issues and plan to drop it down some for some meca shows. I think I can get away with a 80amp fuse and maybe a 60 on burps but not real sure if the 60 will hold up at .5 though. I also ordered a long ram cold air intake so I can put my second battery where my factory air box is.
oh yeah I also found a 200amp alt. I had it benched and it is indeed a 200 amp alt direct bolt on
a 145 with a single 15 is possiable bro, i was doing it with a rd audio alpha 15 an a gp3k for 30sec in usaci's sb class last year at scrapin da coast. never new what it would do fired forward though. good luck an look forward to seeing what you get out of it i love these trunk builds.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
TIG
TIG
Philo Ohio
basshedz06
    May 24, 2024
    May 23, 2024
