2004 Altima 3.5 SE Build
mcsoul
such is life
I've finally decided to upgrade my Altima stereo. When
I first got the car I fell in love with the steering wheel controls,
so I kept my stock stereo and tried to make it louder.
Now I'm over that shit.
I put PAC speaker level to RCA adapters on and ran a few
crappy amps and 2 10" Bazooka subs. It has been less
than stellar for the last 2 years, but way louder than stock.
Up front I've got some clarion components, and clarion
6x9 coax's in back.
Here is the car as it sits NOW
Here is the 2 cubic foot box that my Bazooka 10's are in. I plan
to saw out the holes and drop in 2 dayton HO 12" moofers.
I finally got off my butt and picked up a double din fit kit.
I had convinced myself that I needed to wait until I could
by a Kenwood 8120. Then after I joined the forum I
realized that a lot of people like the stuff in my garage
that I was turning my nose up to. (because I could not control
it off the steering wheel)
Here is the plan:
1) Drop in the Alpine and Kenwood HU/eq.
$80 for install, but I cant find the single din trim
rings //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
2) Buy two 12" Dayton HO's saw out the holes
and put them in the 2 cubic ft box. Run off the
crunch at 125W rms x 2
$280
3) Buy an AQ2200d or similar 1300-1500W@2 ohm, replace the crunch;
remove the 6x9's to let the bass in. I like the AQ because in the future
I could run 1 ohm with some other woofers if I'm looking for a change.
$390
4) Buy the Alpine type X pro's 6.5" or similar, run off the crunch,
or active on the hifonics or some combo of the 2 amps. May need to buy
an external crossover.
$350
5) Buy Sundown SAX 100.2 to run the Alpine type X pro 6.5's, maybe active
with another hifonics vulcan 50w x 2 series vii amp I've got.
$200 used
6) Maybe build a ported box for the Daytons. 3.2 Cubes at 26Hz
$100
I do not have the cash all at once, so this will take me a while.
I will post pics of the install as it progresses.
I got the Head unit and EQ in. I'll post picks
later tomorrow. It sounds way better, except
I have some light alternator whine and a loud
"POPphssT" when when I power off the HU.
I think new RCA's are in order for the whine,
gotta figure out what the heck's going on with
the pop.
nicee 3.5 5 speed. sounds like a good plan
Thanks, and thank you too Mr. C!
The doors actually do not look that bad, they are pretty well sealed
already.
Went ahead bought 2 damplifier pro door packs.
Tim went built me some new rings, we threw some PE speaker tape
on each side.
Cut holes in the a-pillars for the SEAS 27 fabric tweeters
Batcap 2000 and 1/0 run installed, I know, the Power distro is hooked up
wrong, it's only temporary. More to come.
Sneak peak //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Also, dropped the 9842 and Kenwood EQ; went with an 9855 for the active crossover.
Well I purchased a pair of RE SE 12's and the 4 cubes at 30Hz box is built. I just purchased my last amp for the build, an Audison Lrx 300.4 for the mids.
I think I'm going to set the Xovers on the amps as a safeguard in case the 9855 loses power.
Here is the plan (sorry it's so small):
Got it up and running today. May get metered on an AC tomorrow.
That's a deflex pad and eggcrate foam and internal deadening in each door.
A-pillars are deadened too.
I need to go back to stock springs in the rear //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I'm only running about 2000rms. It's holding 13.59-13.79v no matter how hard I've pushed it.
With the car off it sits at 12.6v.
I almost blew up my shit trying to burp it (newb-***).
I'm never doing that shit again. My score sucked
so bad i will not mention it.
Part of the reason I saw later was that others where
burping with no Highs at all, while I just cranked the whole
thing with "Put-on". I must not know what loud is because
honestly it hurt too bad and I could not take it, so I shut it
down real quick.
My stupidass has know idea what song to use, my car's peak
frequency or how to turn up just the bass off the HU.
I will say I'm getting insane trunk flex.
I'm just happy my shit survived. I'm never doing that again.
looking at the trunk lid............where's the deadening?
There is none on the trunk lid, there is some, but not a lot
on the rear deck (where the 6x9's are removed). I'll buy a trunk
pack some day:)
mcsoul
such is life
mcsoul
dfw
mcsoul
