2003 Ford Mustang. amps are gone now i have no audio!
keith805
Hey guys i just bought an 2003 ford mustang and the last owner removed the 2 amps that controlled the sub woofer and an amp that controlled speakers in the car. I have a Clarion VRX775VD. the problem im facing now is i dont have any amps to plug into but i want to get sound from my speakers! Please help!
so he took the stock amplifiers? It honestly sounds like a bad connection somewhere in the headunit
wow you are an idiot how does that even makes sense to what he is asking
op hit up a junk yard and snag a factory amplifier out of an 03 mustang. They are attached to the under side of the rear deck on either side of the factory 6x9 enclosure. A pair of t20 torx screws hold the amps up to the rear deck
It's going to depend on where they caught their speaker outputs at. It would prolly be easier and quicker for you to take it to a shop.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
Please. Quit talking shitt. I might be dumb but I'm not stupid.🤣
16
684
keith805
keith805
Ventura, ca
Louisiana_CRX
    May 20, 2024
    May 20, 2024
