2000 watt sub replacement
1ndatrunk
Can I live?
I have a problem I need you guys to help me with. I currently run a treo ssi15 off of a Vibe 1800d(1100+watts @ 1ohm), in a slot ported enclosure in the trunk of a Cadillac Fleetwood. I plan on buying another Vibe and strapping it for 2000+watts@ 2ohms. I think I want to go with a 12" sub on that power, but I'm not sure what sub to get. I want to get a smaller sub because it would be easier imo to make a custom install look a lil neater with a smaller sub rather than going with another 15. What single 12 could I get that will get a good bit louder than my current 15, that works well on 2000watts? I'm also trying to keep the enclosure around 3.5cuft or less.
a Lanzar Vibe?, is that the amp your using? If so I would be a little weary about how many watts that amp really puts out. My experience with lanzar amps besides their opti amps, are pretty much over-rated...
I've always heard they are in the spl range of a W712 and if thats the case I,ve had the W7 and the SSI is a good bit louder. I'm not sure if they were speaking of the older version of the xxx or the newer one
xxx > w7, in any aspect....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
How loud are those? never heard it, but I have seen one or two on here. How does it compare to an MT or BTL, because thats what I was just sitting here thinking about
You have to take into account that I'm going from a 15 to a 12. I'm doubling power but at the same time dropping cone area almost half. I'm sure excursion will make up for that loss though.
So a new version XXX12 will get louder than the SSI 15? Sounds good to me
1ndatrunk
Can I live?
1ndatrunk
Close
1ndatrunk
