2000 ford taurus help
sdavis1465
I am wanting to use a couple of aftermarket amps with my factory head unit. I have to use factory because of the digital climate control. What I need to know since the tuner and antenna is located in the trunk is where is a good place to run my remote and constant from my eq? I had the remote going to the power antenna switched and it was grounded to a bolt on the front seat since the eq is right by the seat. The problem was it kept draining the battery with no constant hooked up. Where can I run me power wires to turn everything on. I'm no beginner but this is the first time working with this kind of setup.
To Update, I have everything hooked up but cant find a remote wire to connect to. If I take the remote wire from the amps and connect them to a battery wire they amps will work. Any suggestions??
sdavis1465
sdavis1465
Bixby, OK
sdavis1465
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
