$20 for a solution
what are you using to get the signal to the stock amp? any rca?
and you want to use the blue/white from the hu to the amp for turn on...not the antenna lead.
also, you can do testing to see what the issue is....check at the amp to see if it is powering on with a dmm.
How I understand it the new deck sends the signal to the stock amp through the GMOS-04 wiring harness.
So I want blue/white to blue/white then? I tried that and it didnt seem to change my problem.
I'm not sure where to access the stock amp unfortunately.
test the blue/white at the hu with a dmm then....if it is not hot, then the amp will not turn on
Unfortunately I dont have a dmm on hand. Is there another way to test it?
I know if I plug the HU Interupt wire to the blue/white wire it triggers the HU interupt cycle.
a very small light bulb....like a dash light bulb.
touch the blue/white to the end and ground the outer ring.
I used a small flashlight bulb with the blue/white on the bottom and the outter casing hooked to the black ground wire and it did not light up.
i had the same problem and if you did the same mistake then u failed to connect one remaing wire from the harness to the radio. in my case the color of the wire was blue. dont remember which one, either remote or antenna
Maj
Maj
Denver, CO
bass-aholic
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
