2 x ts w3004spl pioneers box ?
wtf is that on top of the box??? is that what i think it is??? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
just wanted to hide the wires and stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Tune it lower for daily aplications... like 28-34hz those subs produce an amazing low end.
That box is only for pure spl and won't sound good at all.
i was talking about the amps... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
theyr so bad ? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
measured
1 x 510 W 4 ohm 12.2 V
1 x 580 W 4 ohm 12.6 V
1 x 800 W 2 ohm 12.1 V
Tune it lower for daily aplications... like 28-34hz those subs produce an amazing low end.That box is only for pure spl and won't sound good at all.
actually that was my wish SPL
ok tnx lads after first test i will decide what i gonna do with the port //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I still think 43 hz is a lil too high. You said u wanted spl. If u have plenty of power then im sure ull get plenty of spl tuned to around 35-38 hz while still sounding pretty good.
I would deffinitly look into a larger amp, those subs are power hungry and will take well over their rated 1000w RMS.
But, as far as the box goes, the size will be fine and the tuning is all your preference so it is up to you. As said, they sound AMAZING when tuned low (I own two myself.)
i thouht alreadu about larger amp(s)
at the moment have no money for that so i have 2 those sony amps at the moment and hope to find out the db-s 11-12 nov on local db drag //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if those numbers will be horroble, i mean too low (under 145) ill go for the new amps //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
i thouht alreadu about larger amp(s)at the moment have no money for that so i have 2 those sony amps at the moment and hope to find out the db-s 11-12 nov on local db drag //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I guarentee you won't break 145dB, hell I would be surprised if you broke 140... But good luck with it.
Those amps don't stand a chance. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My experience with the TS-w3004SPLs is that your electrical system will take a dump before you get close to peak performance with those woofers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
RookieMekanik
RookieMekanik
ireland
RookieMekanik
