2 ports parrellel to eachother, ok?
stickytak
would this be bad? or does it not matter, how they are on the same x,y and z plane?
Wouldnt be really that great.
Best performance would be all subs on one plane, and port on a perpendicular plane.
Better off just having one port.
You may have some phase alignment issues and port unloading.
Ports usually like having a solid surface behind the opening to load better.
Actually, if thats the only way to have subs fit. You will probably have better performance from just 2 woofers.
I wouldn't do it. Wotn sound waves travel from the back of the subs and out the subs firing the opposite direction? I think it would be a distorted mess. If ur that desperate to fit 4 subs than do a true Isobaric
^^^What IamMe said
Yeah, separate into two pairs of woofers.
Also, make sure you have at least one port width of clearance from the wall piece.
Did you calculate for multiple ports and obtain that port length? Port length will have to be changed for each separate enclosure etc..
if you wire 2 of them backwards you wont have any phase issues, i used to run around with 1 sub inverted and 1 not b/c the motor was pretty *****in' and they hammered
as for the port idk what to tell you, im new to building ported boxes
15tallx33widex36deep Wall to wall to 39"
And if I just made one port, but bigger, I dont think the subs would cancel, It'd be just like facing two subs at eachother, right?
or sealed.
if thats all you got fire the subs up, sealed.
stickytak
stickytak
Michigan
iamamp3pimp
