I have 2 Pioneer Premier 3002d2 subs for sale. These are last years model and the dual 2 version. These are the version that actually have spiders, 220oz motor, 1000w rms, 3000 peak. and yes i believe this rating. Ive been giving them 1200 rms, at least before impedance rise and my horrible voltage dro and theyre loud and could use more power. i havent had them long but they were used when i bought them as well. Perfect shape though. all coils read a perfect steady 1.7-1.8 ohms. Cosmetically one of the subs has some scuffs around the mounting frame but none on the surrounds or cones. These are currently in my enclosure in my car but I will at least take some pics of them in there.
Price on the subs is $90 each plus actual shipping.
that enclosure is also for sale if anyone local is interested. just built it this past week. its MDF cabinet grade with some sort of oak or birch real wood finish. its weird but really strong. it is probably a little on the large side for these subs in particular but would work great with most 12s. after displacement its about 4.8 cubic feet including sub displacement. Tuned right at 40 Hz. It is well braced and gets pretty loud. just for fun im gonna meter it on the termlab today and see what it will do. it has bolts for binding posts with lock washers, 8 awg stinger wire inside wired for two amps or one per sub. i want $90 for this box, if you dont want the stinger wire inside ill take ten bucks off.
other enclosure is also for a pair of 12s, roughly the same size with different sub port placement. it was used in my focus trunk, subs were facing forward slot ported on the passenger side. it did a 142.0 at 44 Hz at the headrest. not bad for 1200 watts. it too is wired inside, only this time for a single amp, would work great for 2 12s at 1 ohm. i only want $50 for it cuz it got kinda beat up trying to get it into another trunk. will take pics of it later today. this box doesnt have bolts but actual distro blocks on the outside for ease of wiring. if you dont want that and the wiring ill take 40 for it.
would like to move this stuff quick. looking to build something different asap.
