This amp fed me power for many years. Unfortunately, a couple months ago it started acting up on the right channel (distorted sound output).
I just got my replacement amp, and I have this one that I would like to get rid of. I don't have the time or knowledge to fix it, so let see if anyone else would be interested in fixing it up.
Everything else on this amp works great. I did replace the fan, and it's not mounted very good at all, but it gets the job done.
Comes with book and original birth certificate.
SPECS:
# RMS Power @ 4 Ohms: 100W x 2 @ 14.4V
# Bridged RMS Power @ 4 Ohms: 200W x 1 @ 14.4V
# Signal to Noise Ratio: > 100 dB
# XeTUNE- Advanced input and signal processing circuitry
# Top-Mounted Controls
# 24 dB / Octave Crossover
# Twin-T Variable 0 - 18 dB Bass Boost at 45 Hz
# Auxiliary Outputs Route Full Range Signals
# Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
# XeFlow- Thermal feedback system with output optimization
# Bottom-Mounted Extruded Aluminum Heatsink
# Expanded Metal Mesh Intake & Exhaust Vents
# Ultra-Quiet Variable Speed Fan
# Temperature Monitoring with Automatic Output Optimization
# Superbrite 5mm LED Power Indicator
# XeLOAD- Full power with automatic load sensing
# Load Sensing Optimizes Power Supply and Output Stage
# Maximum Power Output From 1 - 4 Ohms Stereo or 2 - 4 Ohms Bridged
# High-Current Triple Darlington Output Stage
# 150-Volt, 15-Amp, 60 Mhz Sanken Output Transistors
# Direct Insert Speaker Terminals Accept Up To 12 Gauge Wire
# 8 Gauge Power Terminals with Removable Rubber Grommets
# Dimensions: 14 W x 10.6 L x 2.5 H
Higher Res (3MP) pics available upon request.
As far as price, lets say $50 shipped. ($35 for amp, $15 for shipping). Or Make me a reasonable offer if you think that is too much.
SPECS:
