jeremyblevins
hello everyone,
i'm currently in the planning stages of building my subwoofer enclosure for my 2 rockford p210s4. i plan on powering them with a rockford p3001 amp. anyways i am design my sub based of the manufacturer recommended air space for ported enclosures which is 1.25 ft^3 and the enclosure i plan on building is basically 2 ported enclosure because there's a divider in the center to keep both subs from going if one goes. but the closest i can get is around 2.4847 ft^3. should this be close enough or will it effect the sub? also the sub has an fs of 32 hz and i have the port tuned to 33.72 hz is this decent for a well rounded setup or should i raise it to closer to 35 but the port size works for me because it's 2.5x2.5x10 (inside dimensions square). And finally my amp doesn't have a built in subsonic filter so i would need to have one to keep for destroying it's self cause bass box pro at around 24hz the sub will go beyond it's Xmax so what kind would i need to get or if the circuit isn't too complicated i am proficient enough to build one myself.
thanks for you're help and time and sorry for the long paragraph. haha //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
