2 outputs on Mono?
kuijo
I know i've seen the answer for this, but i didn't let it sink in cause it wasn't a problem to me at the time.
I searched and searched and couldn't find it again so could someone help me out on this real quick?
I just got a mono amp in and it has to sets of + and - outs on it? Why is there more then one and could i use both?
Would it be like wiring it in parallel if i did or would i just **** something up?
Thanks for your time
~Mike
Does anyone that own a viper use both channels? I don't know if i can full power if i use just one of the terminals.
It is bridged internaly, and there's two terminals for ease of installation/wireing. So yes you can use both at the same time, it just depends on the final ohm load. You are correct, it will see 1 ohm.
but if i use just one side and hook the subs up to a 1 ohm load and leave the other to terminals alone the amp will still produce full power to the 2 subs?
kuijo
kuijo
TX
AVSTANG02
