2 Orions VS 1 Atomic 5000.1
SPL140.2
Team DefJ
This test wasnt to technical, just did a test using 2 Orion 2500D's wired to .75ohm nominal a piece and the AT5000.1 wired to 1.6ohm nominal, subs used 2-10" AudioQue HD3's in my neon, this was taken on the new TL.
2-Orion 2500D's wired at .75ohm nominal @ 13.7volts burped for 3 sec=147.53db sorry no pic
1-Atomic 5000.1 wired at 1.6ohm nominal @ 13.5 volts burped for 3 sec=145.50db
here was the resistance of the dmm
heres the ohms of the subs to the atomic
so the final ohms of the sub came out to be 1.6ohm nominal.
just a simple comparo against the 2 brands. I was very happy with the AT hittin 145.50 db wired to 1.6ohm nominal, cant wait to get the other one in so i can compare the scores of both amp brands wired to .75ohm nominal. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
egg
here it is installed its gettin lonley by itself *hint, hint* //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
egg
*update* good news the fex ex website says the amp will be in tomorrow so we'll finally see how many db's it goes up from the 2 orions to the 2 atomic 5000.1's all wired to .75ohms //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif than im gonna try it at .375ohms strapped *eeekkk*
egg
I did when i had them, i was the loudest using 1 orion wired to .375ohm than using both at .75ohm each, the difference was 8 tenths of a db. The atomic smoked the orion wired at .375ohms by more than 3 db's but thats pretty much expected because of the ratings on both amps. I just wanna see the difference between them both wired to .75ohms //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
egg
.35 is for sure it's sweet spot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Just make sure you got the batteries (which I am sure you do) and let her rip!!! Just watch the voltage and giver'
Keep me updated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I like to see happy atomic users, as well...what kinda electrical are you running?
Shawn
i got a 200amp Iraggi alt
stock batt up front and a kinetik in the back my other amp should be in tonight than i can have good comparos
egg
SPL140.2
Team DefJ
SPL140.2
NY
jimmyslide
