2 ohm stable amp suggestions?
http://www.db-r.com/sell/store/
Check out our refurbished amps. Same amps, 1 year warranty. Less money. But if you are wanting a SAZ-2000D, none are availible in refurbished right now. There is a SAZ-1500D though I think, and it will do 800-1000 rms @ 2ohm depending on your impedance rise and your battery voltage. It will also run at .5 ohm but will likely tear your subs a new one with 1800 or so watts....
what did you mean with: "It will also run at .5 ohm but will likely tear your subs a new one with 1800 or so watts...."
i didnt know sundowns run at .5 ohms. do they really?
also does anyone running sundown amps know anything about that dual mono thing. i saw the 1000 watt one and it said at 2 ohms it will do 600 watts rms, but at dual mono mode at 2ohms it will do 1800, whats that about? or how would i get my amp to run that way
robertoyoung08
robertoyoung08
bay area, ca
robertoyoung08
