2 ohm, or 4 ohm
Get the Dual 4 Ohm subs so that together they can be wired to a final resistance of 4 Ohms like in this diagram:
Then get this amp since you've stated your on a tight budget. Under $180/shipped, will give your subs more power (when run in 1ch. mono bridged mode) than either the amp you have or the other one you suggested, and the eBay seller I linked to is trustworthy.
It still isn't all the power that those Rs would want but it's a temporary fix until you have the opportunity to do otherwise?
Puppet Master
Puppet Master
Fargo, ND
Prowler573
