2 ohm or 4 ohm woofer.....
I was looking on Precision Power website. It would be dual 2 ohm or dual 4 ohm. I have not bought my mono amp or woofer. Still trying to put to gether a combination that will work in a 3.5 ft3 ported box.
Specifications:
Model Number PCX 102 PCX 104 PCX 122 PCX 124
MSRP $179.99 $179.99 $199.99 $199.99
Thiele/Small Parameters
Fs (free-air resonance, Hz) 37 40 22 24
Vas / Liter / ft3 21.1 / 0.75 18 / 0.64 124 / 4.38 112.2 / 4.32
Qts (total driver Q) 0.75 0.79 0.53 0.54
Re (DC resistance, ohms) 3.7 7 3.7 7
IMPEDANCE dual 2 Ohm dual 4 Ohm dual 2 Ohm dual 4 Ohm
well if the mono amp is 1 ohm stable or 4 ohm stable only i would go with the dual 2 ohm
if the mono amp is 2 ohm stable i would go with dual 4 ohm
is this for one woofer only?
one woofer... yes.
I have heard many 2 woofer sealed systems and they sound tight and kind of clappy sounding. I have had good luck with a 12" woofer with a port. I had this set up in my F150 and it sounded good. My Tundra 2008 has 12 speaker JBL now I need some low bass.
I will buy an amp that is 1 ohm stable
just one 12 inch sub.
The truck has a nice 12 speaker JBL system. Now I want to add some good low bass. I want to find a good set up to run in a 3.5 ft3 box that will have a 3 inch port.
I havent been in the car woofer market for 3 years now and want some suggestions! A friend of mine suggested Precision Power....
What is the BP power? I have looked at these woofers from Fi.
What amp do you suggest for the 12 incher?
I read that Fi has 4 levels of subs... why did you suggest the 2nd lowest?
What is the BP power? I have looked at these woofers from Fi.What amp do you suggest for the 12 incher?
deends alot on what you are lookin for in sound and how much power you will have on tap
I prefer lower bass as the trucks JBL system has quite a few mids and tweeters!
I can add a good mono amp...
With the BL12 what amps would you recommend?
With the Q12 what amps would you recommend?
Then I could check prices and see what I would be interested in.
mannyahles
mannyahles
Carlsbad, Ca
mannyahles
