2 ohm bridge
Originally posted by AtomicGuY OK jbl_marshall21
I think you are the man that can help me out. What am I doing wrong?? I got the same setup as you except I'm using two 15"ers. I want mine to setup exactly like yours. Can you help? My AMP for some reason cuts out when both subs are connected to the amp. Is there a special way you hooked yours up??
I'm scared to think there is something wrong with the amp now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
AtomicGuY
r ur subs svc?
Well, I finally solved the problem. This was actually a weird solution. What I did to fix the problem is take the pos to pos on Speaker B and neg to neg on Speaker B... then inverted them so positive goes to negative and negative goes to positive.
I now have both subs pounding hard on this AMP!
AtomicGuY
jbl_marshall21
important person
jbl_marshall21
nebraska
MikeofTulsa
