2 Obsidian 18vs vs 1 DC XL18
You might need a little bigger box for an 8" port I know the volume if a single 8 is equal to the same as a pair if 6's but the larger port may not let the subs unload the same as the 2 smaller ones will
actually i had 1 18" hdc3 18 before the 2-15s and my single 18 was louder then the 15s.....
Must have had a **** box then. 1 8" aero *****. I ran that with 2 12's. U are trying to stuff too much crap into too small of an area and hoping aero ports will make it not ****. Good luck.
i already have one built to use, and i made to were i can change ports etc easily. i thinks its 5.5 cubes net after all displacements. And power will be around 3k
so you've already made the box and are just planning on what to throw into them? Is that 5.5 cubs net and your trying to fit two 18s in that box? 5.5 is only enough for 1, 18.
Go with a single XL, HDC4, Zcon, DD9918, or whatever beastly 18 you can find.
no i was trading of my 2 18s for 1 single decent 18
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
