Ok, I figure I won't get much interest on here so I won't include all the info...
I have one that is sealed, under-strut designed for 2 10" subs
Here are specs:
Nissan 350z 2-10" Subwoofer Enclosure
with Amp Rack, More Mounting Depth,
and More Airspace.
This box simply slides in under the strut bar and forward then the amp rack sits directly on the back of the box. The amp rack was designed to sit directly on the chamber of the box without using make-shift legs to elevate the amp rack. GREAT DESIGN!! EASY INSTALL!! GREAT BASS!!
Airspace: approx. 1.41 cu. ft. total. The box is divided into two chambers with .70 cu ft per sub/chamber.
Mounting Depth: 8.5"+
Mounting Hole: 9 1/8" this is standard for most 10" subwoofers
Condstucted with 3/4" MDF
Sealed Airtight
Terminals installed ready to wire
Covered in high grade Automotive Black Carpet.
I have another that is designed for 1 10" behind the strut bar and here are the specs for it:
2003+ Nissan 350z Coupe Custom 1-10" "Type S" Subwoofer Enclosure.
Want a Steathy sub box for your Z? Here it is...ZEnclosures newly designed "Type S" enclosure.
This is a Custom Made Sub Box for a single 10” subwoofer for a 350z. This box is Covered with Black automotive carpet with a 9 1/8" hole that will fit most standard 10” subwoofers with 7" or less mounting depth. (10" Alpine type R is used for the pictures)
Amps can be mounted on the top panel.
Box is installed in front of the strut bar with no bolting needed.
Approx. .80 cubic feet of airspace.
Constructed with 3/4" MDF Board
Sealed air tight
Connection Terminal located on side panel
I can post pics upon request.
I am located in 30345 and shipping will be approximately $35
2 10" -- $95 + shipping
1 10" -- $95 + shipping
I have a full list of refs on my school computer but some include:
sold to:
Nucleareskimo, woody89, sporty_drew, and 2 more
bought from: flakko, revrider1, imaspaceguy90
I will post pics upon request and feel free to PM me with any questions
Here are specs:
and More Airspace.
Sealed Airtight
Sealed air tight
sold to:
