2 mojos..... what amp?
Enlighten me. Why is a sundown 2000 better then the mb quart 2000.1d? The crunch gp3000d is an underrated 3000 rms amp. The sundown or audioque will not produce 3000 rms. Gp3000 > sundown 2000 and audioque 2200.
Wrong, The Crunch is not underrated. And of course a 3K amp will do more power than a 2K amp, im glad you know math. The Sundown 3K will stomp a crunch 3K, period. And the MB Quart does rated as well. the SAZ-2K does more than rated and can be dropped lower.
Not all Maxxsonics amps are the same. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
MB Quart 2000.1D > SAZ2000D
Wrong. SAZ will last longer, drop to lower Imp's easier, put out more power and looks cleaner.
Why would you run an amp at .25? Are you stupid? how bout you run them normally at 1 ohm. They will last longer //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Obviously you dont know anything about box rise. You wire it to 1 ohm and the amp wont see 1 ohm. Period. If you knew anytihng you would know this.
I'm a real g, ain't got shit to prove to nobody. You think I crank it full tilt daily? Once again jackass, you fail.
You dont have ot prove anything, we know you are full of shit.
Lol na your just a P.O.S scammer who has to lie to make his E-Peen bigger....
This.
I have 1 15 in a trunk. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif I don't need to show you shit. I ain't got nothing to prove. You guys are **** anyways. I'll put my other 15 in and surely be doing 160 easily.
Wrong. Even if you were hitting 155 which we know you are not. Adding 1 more 15 with no upgrade in power will not give you 5dbs. You might get 1 if you are lucky. Keep your mouth shut scammer.
you are so full of $hit. how old are you, because you are sounding like a 12 year old now. "surely be doing 160 easily" you have no idea what it takes to do 160db. there are a handfull of ppl in the country that can do that and you, some little child from nebraska thinks that you can do that. ha ha ha ha ha
orphe
orphe
Houston
orphe
