(2) MOFO 15's or (1) RE MT 18
  • (2) MOFO 15's
    Votes: 25 35.2%
  • (1) RE MT 18
    Votes: 46 64.8%
  • Total voters
    71
Get back to testing that autotek!
its gotta be here first //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
as I said in the termpro post.... when it arrives //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Loyd L.
not doing accurate testing?
I guess I won those 2 world championships on accident..
lets see.. SPLW 12" model..
big, ugly, and and a brick..
suffered from a rather bad case of flux modulation (go look that one up)
tested in 1.5, 2.5, 4, and 5 cuft ported, tuning from 35-55hz
power on tap was at first 1kw, then cause the numbers were so bad, 2.5 kw, and the numbers were still bad...
testing was done in a geo metro if I recall correctly... Linear X was used for measurements..
long story short... every other woofer owned it.. except the mofo //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
even a piddly comp vr 12 we had lying around, whooped on it, and it was an older one too, back when creedence was still makin them....
then we got evil and laid 6kw on it, and the rest of it is boat anchor history..
Loyd L.
Ok good test //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
1) its rated at 1100 wrms and max power is 2200 watts
2) Id hope itll have the magic smoke at 6kw BTW so did Marvin Smith's (Team BassAttack) RE SX 12 with 3400 wrms an Orion 2500D to each coil;)
That also made a great boat anchor //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I would choose the MT mainly because of the Driver it uses. But then again the 2 MOFO's have twice the cone area. So yeah, iono. I'd still pick the single MT though but only if you going for SPL purposes.
A wall of cheapass 6x9s period.
That would be sooo cool.
Maybe 8 6x9s side by side with a slot port coming over the top of the box, prolly sound suprisingly good.
Loyd L.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Hurrrryyyyyy!!!!
This will definitely be all out SPL. I think the MT will put up some impressive numbers with the (2) A3000's I will be putting on it.
yeah, its just that easy //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Im afraid that's all the detail I felt necessary to fit into a one sentence reply. If you'd like to give a long and detailed reply on how to install a winning system, be my guest. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
1st you need to .... LOL J/K im still testing mine out its never ending //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif But thats the fun of it.
with the MT being QVC, it prolly will be impressive //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Oh and you'll need a hella good alternator.
I am quite sure you can get an MT in a dual VC configuration as well, at least that's what RE has on their site.
I have a 200 amp Alternator on its way. YEEHAW!!
Goldtaz1
Goldtaz1
Montgomery, AL
SPL140.2
michigan born
    May 14, 2026
michigan born
    May 14, 2026
