2 l7's not what i expected
i just got another L7, got it hooked up and all , but its not what i expected, its not much louder just more "intense" i notice if there is anything at all on the seat or dash its instantly boucing around and everything shakes but i dont notice it being much louder at all, and i notice the volume act's kinda differntly , where as before i could turn it up to 20 to get max output now i can put it up to like 22-24 (being very careful though) and i cant tell when it distorts? with 1 l7 i could easily tell when im pushin it to hard , also sometimes it looks like both cones arnt in sync with each other @ full volume like one looks like its in mid-excursion while the other is all the way out.... just some things i noticed after upgrading
Sounds to me like cancellation. If one was out of phase, you would have a very noticable decrease in output. Try playing them with the trunk popped or the windows down and see if the difference is dramatic. You should probably hear a difference anyways, most every system has some cancellation, but it may be more dramatic than you think. If it is, try moving your box around.
Your problem is the amp.You had great power for one sub but now you arent really puttin anything on them if all you have is the 1500d.
exactly what i was thinking, at 2 ohms it was rated @ 1000 watts to 1 sub, so in reality mayby 700 watts , at 1 ohm its 1500 watts but in reality mayby 1000 watts? so im actually puttin less to each sub @ 1 ohm than just having it at 2 ohms running 1 sub
Twistid
Twistid
in a space out of sound
Beermanpb14
