jblaze1984
I have 2 JL Audio 10W1v2-4 600 watts max 300rms im putting in my ridgeline with a downfiring box. My question is which amp would you reccomend? and would you run it 4 ohms or 2 ohms?
JL Audio J2 360.2
•2-channel car amplifier
•110 watts RMS x 2 at 4 ohms (180 watts RMS x 2 at 2 ohms)
•360 watts RMS x 1 at 4 ohms
•Class AB amplifier design
•differential-balanced inputs
•MOSFET switching power supply
•frequency response: 10-35K Hz
•variable high- and low-pass filter (50-500 Hz, 12 dB/octave)
•variable bass boost (0-9 dB at 45 Hz)
•preamp inputs and outputs
•speaker-level inputs
OR
the JL Audio J2 250.1•mono subwoofer amplifier
•175 watts RMS x 1 at 4 ohms (250 watts RMS x 1 at 2 ohms)
•frequency response: 10 Hz - 100 Hz
•variable low-pass filter (60-240 Hz, 12 dB/octave)
•wired remote level control included
Thanks for the help and input
JL Audio J2 360.2
OR
