(2) Digital Designs Z-SE Amps #10, #15
ahole-ic
Banned
Item(s) for Sale: Digital Designs Z-SE Amps
These items have been used. #10 is basically mint. #15, the bottom vibrated some so I put tape around it and now it's fine. No problems are known to me at this time. I just uninstalled them from my vehicle and listed them on here.
SPECIFICATIONS
Series Z
Input Sensitivity 0.2v-6v
Variable Subsonic Filter 10-50Hz @ 24dB/Oct
Variable Low Pass Filter 35-250Hz @ 24dB/Oct
Clipping Display LED on remote
Tested Voltage 11.9 VDC
Tested THD ≥1%
Model Z-SE
Damping Factor >150
Cont Power at 1 ohm 4950W x 1ch (I've clamped it at ~4000 at 2.34 ohms on battery power. These amps are under-rated some.)
Dimensions - mm 762L x 301.5W x 71H
Dimensions - inches 30L x 11.9W x 2.8H
$1400.00 Each including shipping.
Included in price. It costs between 30 and 50 dollars in the continental United States. I will ONLY ship to the continental US. No other countries. No islands or outlying territories.
im really only interested in number 10 cause it seems like number 15 isnt in mint condition,i bought my number 30 off of spy on this cite and it is mint shape
Eh it's ok anyways. I don't want that z2. I've already had one. Also, I'm not sure what you're referring to about not in mint, but your assumption isn't correct.
sorry i wasnt offending anyone you had just mention you had to put tape on the bottom of number 15 cause you had some problems thats all!
No offense taken man. Yes there is tape on it but it wasn't due to a problem. It was put there to prevent one. I highly suggest it for all korean made amps. MOST of their failure is due to the backs falling off and shorting internal components. Just a heads up.
ahole-ic
Banned
ahole-ic
Ivory Tower
Totaldomination
