2 cvr 15s + 1 Sundown 1500d = 147.3
thats nice..for a pair of 175 dollar pair of subs..what numbers was ur 2 18" BLs doing b4 u upped to 3?
Yeah, considering these are like entry-level subs w/ a single 1500watt amp i think the #s are darn good. My bls hit a consistent 148.3 w/ a 1500d on each @ 1ohm. That was the daily setup and it would pound full tilt all day long.
I did test them once w/ the 1500s strapped and it hit a 149.5 @ half volume before going into protect. The bls are technically 1.5ohm coils and I had all four parallel for a 0.375ohm load then the amps strapped to that so each amp was seeing 0.1875ohm. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif Since adding a 3rd sub I'm only seeing an extra 400watts out of the amps so my #s barely went up.
I've seen 151 out of 4 cvr 15's on a kicker 2500.
I've done 150s w/ 2 T1 15s on a pair of 1500s. //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
Edit...
^^^and that was in my big freakin Yukon @ 41hz.
@ what freq? and what did they do on music.
This score will get better. It did manage a 147.4 on one hit but was consistently nailing .3s. There are a couple lil tricks I want to try today as well as adjust the tuning and see what happens. I'm shooting for high 47s possible 48 flat w/ this. I'm gonna resin the inside of the box this week to see if it will help w/ air flow.
roarzorz
lulzorz
roarzorz
vag
tooloud4tv
