2 channel and mono?
dredey
i have 2dvc 4ohms type r subs
and i want to wire it to a audioque 1200d amp
all the pictures of setups ive seen only use one channel like mono
but the audioque has 2 channels
so do ignore one of the channels and just use one of them like the figures tell me
or do i use the + from the first channel and the - of the last channel
thank with anyhelp i dont wanna ruin anything that i bought
and i plan on wiring it either to 1ohm or 4 ohms
i need to listen to how each sound to see which one i like the most
The AQ1200D DOES NOT have two channels. What it has are two sets of speaker outputs tied to the single MONO output. How you wire it is up to you. You can wire one sub to each set of outputs OR use only one set of + and - to wire both subs.
Series the voice coils on each sub then parallel them for a 4 ohm final nominal load OR parallel the coils on each sub (+ to + and - to -) then parallel both subs together for a 1 ohm load.
Click *here* for your wiring options!
dredey
dredey
houston tx
dredey
AJ (ACE)
    Jun 28, 2026
