Yea, if your amp has RCA outputs it will be full range and you can run from it to your new amp.
You will not be able to adjust sub levels, fade, and such since they share the same output, but yes it is an option and it will work.
As said above if your amp does not have RCA out, split the signal with Y adapters.
None of this is optimal, but it will work.
