2 amps or 1 big amp! please help
Roberto Palofox
hey im new to this site and i need help. i have 4 12'' hifonics brutus sqaures i bought and i need to know which route i should go on as far as the amp/amps. this is my first system i build from the ground up. the subs are DVC 4 ohm 600watt rms 1200watt peak and they will be in a custom box tuned at 33hz firing up. thanks for the help.
ahahaha that simple huh.... alright bro. i been getting alot of mixed anwsers here locally so i thought id try this forum. alot of people recomended 2 amps, one for each pair wired to 1 ohm.. thanks for your help
The amp is 2 boards in 1, hence why you can run 2 ohms bridged or 1 ohm to each side. Easy to do 1 to each side. It will also have the power you need. Plus they are cheap to buy for the power ya get.
Roberto Palofox
Roberto Palofox
phx , az
Phoenix Risen
