2 AMPS Each Supporting Their Own Sub.
in order to run both signal ires, you will just run your original rca's to y splitters. you will need (2) female to two male y adapters. for the rest of tthe wiring you will use a distribution block for power and ground (seperate blocks) and then you just run your wire in and it gives you multiple wires out. check out http://www.knukonceptz.com for your wiring needs
NickAMonzo
NickAMonzo
Paso Robles, CA
blackbonnie
