2 amp system help
mkirby112
I am going to be installing a jl audio 1000/1 amp and also a jl audio e6450 six-channel amp. I am new to installing multiple amps.
If i run the rcas from the head unit to the 1000/1, can i use the output on that amp to run another set to the e6450? Or will i have to run another rca from the head unit for that one? The 1000/1 will be powering a 13W7 and the e6450 will be powering my highs. Thanks
if your head unit has 3 pre outs, the sub pre-out will run to the 1000/1 while the other 2 pre-outs (front/back) will run to the e6450. you will need to run a 2 channel rca, as well as a 4 channel rca.
Guys, I do not know if it escaped your attention but he needs a total of 8 channels worth of input for the amps.
Excepting if he is planning on partially or completely bridging the output(s) on that 6 channel unit...
It would be greatly helpful to know what kind of HU is being used for this, though.
Excepting if he is planning on partially or completely bridging the output(s) on that 6 channel unit....
what if he didnt use them at all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif otherwise he could get 2 y-adapters on one set of the rca's to run 6 channels to that amp.
i was wondering the same cause i have a pair going to by directed and then the other 2 pairs going to the 4 channel but i have my other 2 channel amps also. The 4 channel has an rca out with a variable crossover filter can u use this to go to the 2 channel
mkirby112
mkirby112
Kalamazoo, NI
PESteele
