2 amp questions PLEASE HELP
msh0271
Hey guys thanks for reading. I signed up for the forums to ask 2 questions from some people who know what they're talking about. Im sure these same questions have been asked but I don't have time to read through everything.
My first question:
I have two PS3 Fosgate 12's. DVC 2-ohm. Wired to a 2 ohm load. Cant remember if that's series or parallel. But anyway...I currently have an Alpine 500 watt mono. Rated at 500x1 at 2 ohm. SO does that mean that there is a total of 250 watts going to EACH speaker or 500?
This leads into question number 2:
My speakers are rated at 600 watts RMS. IF the amp is only putting 250 to each speaker I feel like I can use a much larger amp. If I go with a 1000 or 1200 watt mono amp wired at 2 ohm will that be putting 500 or 600 watts to each speaker? That's what I would like, about 500/600 to each.
With that being said what amp would you guys recommend to push the hell out of these speakers. Being reasonable and a budget of no more than $400? Without getting into the BIG 3's and all that technical stuff. I'm using these in my boat. Amp just runs off two deep cell batteries. Don't get me wrong it sounds good now, but I want a little more. I guess I ended up with three questions. But thank you for any help.
My first question:
250 to each
you could gain up to 3db which is right at the noticeable difference range.
msh0271
msh0271
Scottsboro, AL
mylows10
AJ (ACE)
    Jun 28, 2026
