(2) 4 ohm 10 inch JL subs to 1500 watt mono amp @ 4 ohms
  • 4
TeeRay
Wussup everybody, I have a hifonics 1500 watt amp which puts out 500 watts @ 4 ohms that I bought awhile ago, my 12 inch pioneer blew on me, so I thought about getting two 10 inch JL audio 10's 4 ohm (75-300) watts a piece. I was wondering could i wire them to share the 500 watts? (250 watts to each sub)? The amp has two inputs (2 positives and 2 negatives). Thank you in advance!
It would help if we had model numbers.
I'm GUESSING you have the hfi1500d and you're looking at 10w1v3-4's.
If that's the case - yes, they'll work well with that amp.
You can wire the svc 4's parallel for 2 ohms. The amp is "rated" for 1000w at that impedance, but its actual output is quite a bit less than that -- probably in the 700w range.
Keep the bass boost off and set the gain a bit on the low side and it will be a good match.
The amp has two physical outputs, but it is still just one channel. A lot of mono amps are set up that way because it is common to need to run more than one speaker lead.
You can connect one of the 4 ohm subs to each output (a parallel connection) giving you 2 ohms at the amp.
Aw my bad bro lol yeah I have that amp: http://www.amazon.com/Hifonics-Hfi1500d-Watt-Block-Amplifier/dp/B003PSCBUQ but both subs are dvc: JL Audio 10W0v3-4 W0v3 Series 10" 4-ohm subwoofer at Crutchfield.com So I can't wire them to 4 ohms at the amp, so the subs can split the 500 watts, so I wouldn't be pushing it too hard? Also, I was just going to go with 2 Rockford Fosgate 12's Rockford Fosgate R2D4-12 Prime R2 Series 12" subwoofer with dual 4-ohm voice coils at Crutchfield.com My budget is kinda low. Thanks for the reply.
Same story with the w0's - they're SVC 4's so you could wire for 2 getting 300-350w per sub. That would work well.
The RF's being dvc 4's could be wired for 4.
It also lowers the amps efficiency and raises the current draw.
474
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
310
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
TeeRay
TeeRay
Chicago, IL
n2audio
    May 18, 2024
    May 18, 2024
