2.4, 15" Mag, Sealed..Box Log/Help
SHOemup233
NooB!
Sorry, no pictures yet. I will be building the box this weekend. Just going to go out and get the supplies tomorrow. Hopefully starting friday, saturday.
Dimensions will be 15.5 deep x 17 high x 18 long.
To be about ~2.4 cubes I'm pretty sure.
This will be my first box, so any tips before I begin?
What other woods would be possible besides 3/4" MDF, although I am assuming it will be 3/4" wood. What would be best?
What screws do you guys prefer?
And I have read enough to know to use wood glue not anything else. Should I also use silicone to seal? It probably won't be carpeted.
Any tips are greatly appreciated. It will be for a 15" mag, if I should change my box design also let me know.
Thanks
i used some fat wood screws on a box and that was terrible. Make sure the screws are pretty skinny. Sand, glue, screw is what i would do. If you get nice straight accurate cuts everything after that is easy. Take your time on the cuts and measure twice cut once.
Sorry, no pictures yet. I will be building the box this weekend. Just going to go out and get the supplies tomorrow. Hopefully starting friday, saturday. Dimensions will be 15.5 deep x 17 high x 18 long.
Thanks
that box will be more like 1.9 cubes net, not sure where you came up with 2.4.
Building a sealed box is pretty simple. My advice, measure twice...cut once //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. Make sure your cuts are straight and correct and you'll be fine.
How did you figure out the cubic feet? The way I did it was obviously wrong. ha.
I'm looking for about 2.3-2.5 cubes after sub displacement. So 2.5-2.7 before.
With 3/4" wood, how much wider should I go? Thanks
How did you figure out the cubic feet? The way I did it was obviously wrong. ha. I'm looking for about 2.3-2.5 cubes after sub displacement. So 2.5-2.7 before.
Any of those dimensions you would like to remain constant? Like do you have a particular space your trying to fill?
EDIT: I get 2.07 ft^3 for your original dimensions, to make it 2.7 before displacement you would have to go to a width of 23"
Well guys...
I was literally turning into home depot and my battery light turned on, accompanied by a loud whine when above 2000 rpms. The light turns off when I'm above 1500 rpm's, but below that the lights dim badly. So I'm assuming my alt is gone. On the way to home depot to get the wood for my box. The worst coincidence.. So I won't be able to make a box at least until next weekend. Thanks for all the help guys. I'll let you know when I start up again.
SHOemup233
NooB!
SHOemup233
Brighton, Michigan
SHOemup233
