2 18's or just 1????
well thanks for the input, arguements, discussion or whatever you call it.. haha.. so is it agreed that i should go ahead and go big with both of them ???
yeah if you already have them you might as well use them both make sure you brace the box
i think it time to start banning 09ers already....
HAHAH.
Anyways, if you have the space, do two. I mean, from what you're talking about, money is no concern. However, a single sub in proper airspace will sound alot better than two subs that don't have enough room. So if you have a giant *** car/SUV, and the time, do them both. Ever considered a sealed application? That will cut down on box expenses, technical difficulty, etc.
HAHAH.
yea i thought about sealed.. i just havent had much luck when i build sealed boxed.. i know it sounds wierd cuz all it is is looking at the recommended size for the sub, but still... anyways, i would rather go ported for lower more painful bass.
HAHAH.
MT's sealed= EWWW
Did a box that was 8.5cubes @ 35Hz for a single MT 18. Off 2k of power it did around a 147+ at like 34Hz. Sounded fine for daily also.
I'd do a box for both since you have them and the power to push em. Window bracing would be my choice and a port in the center if possible as it'll double as bracing.
sweet.. thanks for the info!! yea, everyone has been saying to go ahead and go with both...hopefully i can get into the mid 150s then with both of them....
rickymac21
2loud4u
rickymac21
washington,OH
rickymac21
