(2) 1500d + 1ohm = ?
You cant strap them and run a 1 ohm load, that would mean each amp sees a .5 ohm load which would burn those amps up... So output @ 1 ohm is smoke //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you are looking to strap them, you might as well get the 2500D, 2500w @ 2 ohms.
correction.
VIPER amps can only go down to 2 OHMS
ORION amps can go down to 1 ohm and in some instances .5.
...//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif No one mentioned Orion. Don't wink at me for your mistake.
you said 2500d.
i ASSUMED orion (as would almost anyone else).
you didn't SPECIFY which one (since both were made by directed/dei anyways).
you know what assuming leads to. it makes an *** of U and I.
/threadjack.
my sub is an HD312 and its a D2 config. what about running each 1500d to its coil? isnt there a directed 2400? anyone know the specs on that? i need a decent amp to put around 1800
dleccord
dleccord
Sacramento
dleccord
