2 15" 9500 enclosure (sketchup inside)
sinosic
Idyllic Enclosures
mtx says 2.25 cubes each with a 2" wide port for a ported box. seems small for a 15". i messed around with bbp6 and came up with this design. 3.5 cf each after all displacments. tuned around 32hz. the port is 18.5" wide x 2" tall x 24" deep. angled piece of mdf on the back bottom wall of each chamber.
low deep bass is what im shooting for. whatcha think?
around 1000 watts rms to each sub by 2 mtx amps
going into a denali sitting on 26" giovanni rims. ballin
im thinking loud to. but kinda tripping on why mtx suggests a *Net Internal Volume: 2.25 cu. ft.
*fB =29 Hz
thats crazy small after displacement its even smaller
im thinking loud to. but kinda tripping on why mtx suggests a *Net Internal Volume: 2.25 cu. ft.*fB =29 Hz
Yeah I ran a couple of different setups when I ran MTX 9515's... One I went with the 2.25 cubes ported each with 1000 watts a sub...
The other setup i went with close to 4 cubes per sub and the ports could fit 24 packs of beer down them. I sent those a 1501d each and it sounded much better than the 2.25 rec. from MTX (I actually got the specs to build the box from some MTX tech when I called them asking about it).
I think the 3.5 per sub will do great //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
-B
-B
thanks, i needed that
anyone that can drop 10 grand on rims alone is balling. even if they have one 10"4 15s or 4 18s is called "groundpounder"
i disagree..if i have $10,001 in the bank and i spend 10k on rims...im definitly not ballin. yet i could still have those rims. if i have a 1979 amc pacer and put 10k rims on it..thats not ballin. if i have a 2008 denali on 10k 26"s with a plywood box in the back holding 4 12"s..thats not ballin. complete package homie
sinosic
Idyllic Enclosures
sinosic
roseville,ca
IgnoreMe
