2 13w7s needin advice
you other option is to wire to .375ohm I believe and your amp will not handle that
why would you say it then? lol
anyways yeah your amp cant do that run with the link he gave you at first...but ultimately get a bigger amp or another one...
or just run one of the subs
With the subs wired to 1.5 ohms like is described in the link, your subs will sound just fine. Don't buy into the whole "underpowering" nonsense. Your amp will push somewhere in the neighborhood of 1500 watts to those two subs which is more than enough to get them to get very loud. This is assuming that it is the bdcp amp. If it were an older one, it would do slightly less(1200-1400) at that 1.5 ohm load, and you probably would not be able to hear the difference.
+1
+1
I looked up the specs on the new rockford power1500 and...
Rated Power
(RMS Continuous Power):
1000 Watts x 1 @ 4-Ohm
1500 Watts x 1 @ 2-Ohm
1500 Watts x 1 @ 1-Ohm
so wired to 1.5, you should get the 1500 max rating and I agree with the other guy, it will be loud.
mulletman.zane
mulletman.zane
Centralia, IL
maddog
