Sold 2 12" Type Rs W/ MTX Thunder 1501d
tylork92
Title Says it...i ahve 2 12" Alpine Type AAARRRGGGHHHHSSSS. Also have a MTX Thunder 1501 d. EVERYTHING WORKS FLAWLESSLY AND CAN GET A VID TO PROVE. the amp i will say is 10/10 functionality and cosmetically i would give it a 9/10 simply because of a couple scuffs on the top which i think i can buff off. The subs are the newer version. Only 1 problem with ONE of the subs. when i was putting them n the box a spider crawled up my leg and the drill slipped and the bit poked a small hole in the surround...i repaired with clear silicon immediately. I kno only one pic is with username but if need be i can get more.
PRICE - CAN ONLY USE USPS MO.
subs $100 ea. + shipping
amp $225 plus shipping
can get everything locally for 450 including the box pictured.
MTX mp on the left is the only one for sale.
can you post a close up pic of the repair on the surround? also what coil config. on the subs?
Ill get that for ya later on today..im bout to head to school and then work...may be tonight before i can. And there D4 coils btw. The repair is very minimal...all that happened was the tip of the philips bit poked through it...kinda in the side of one of the ridges...ill get you pics later tho.
and the amp is rated at 1500 @ 2ohms.....if modded to 1 ohm itll probably do close to that Funkin.
tylork92
tylork92
North Carolina
tylork92
