2 12"TC LMS4000 or single 06 15xxx
TC 5200* (not LMS 5200)
LMS 5400:D
18" LMS-5400:naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty:
only 200 off //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
We compared the XXX to the Rl-S and they are very close contenders...I cant imagine what a 5400 sould be like. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I cannot imagine how much *** 2 of those LMS-5400s would kick in an IB/Dipole/LT setup for Home Theater...
The 15" LMS-4000 wants a massive box as it is... 14+ cubic feet for a .704 Qtc:eek: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I cant imagine how big of a box the LMS-5400 18s would want...
Unless the 15 can work in the box i have right now i really cant consider it. I really dont want to build new box when the one i have i really like. As for the 12's the tc4ks look very promising.
The 15" LMS-5400 wants no more than 3.5 cubic feet for a deep ported box (below 20hz) I'm guessing you can use the 15" in a box under 3 cubic feet ported and even less sealed for a car. It will want to live in ported boxes (bigger boxs will be louder)
You don't always need a Q of 0.704 or 707. You can cheat a bit and its not noticeable. Also this speaker behaves a tad different at higher input levels because the Q does not dynamic rise like non-linear speakers as the excursion rises.
The LMS-5400 will **** for IB, don't try it, its a waste! But the 15" 4k will be aweseome for IB.
I guess I assumed the LMS-5400 series drivers were like the LMS-4000s just on a higher plain (more of everything, still maintaining the huge displacement and extreme low-end roll-off)
are the LMS-5400 series drivers designed for a high BL, low Qts? High Efficiency, Small Box, (sacrificing low end extension). Are they designed with the same goals as the TC3000 (loud, small box) just with a linear motor?
I guess the LMS-4000v2 was designed for High Efficiency, Low End Extension, (no small boxes...)
No sacrifice on low end extension, the LMS-5400 will hit subsonic frequencies with more impact than the 4k if that’s your question.
The 54 is designed to do it all yet. Loud, low, efficient and clean.
lslugz
MexiCAN
lslugz
Northern VA
CBFryman2
