2 12" subs needed...$400 budget...2000 @ 1 ohm
"The SDC2.5 was designed for 500-600 watt per driver sound systems, this matches well with the 500-600 watt mono blocks driving a single woofer, or the 1000-1200 watt mono-blocks driving a pair of woofers."
I'm not quite sure that those fit my needs. I'm giving 2000w to 2 subs. Now the HDC3's are, but they are out of my budget
Sundown SA12's would work perfectly.
Two SWR-1223D's in will be insane is a well built 1.5-1.75 cubes each at 33-35Hz. Give them at least 30in^2 of port to let them breathe.
Does that amp have a subsonic filter? Is it adjustable? If so, set it at 30Hz to protect the subs and they'll take 1k RMS all day long.
you can give a pair unclipped just fine.
focused313
Learning With Every Post
focused313
Michigan
05fronty
