2 12" alpine type x's
hockeytoker
could two 12" type x's take a aq3500d amp wired to 1ohms?
or would it be better to run them on the aq2200d amp?
also box recommendations? i no it should be sealed an tuned to 32hz but how many cubes should i give each sub for them to perform there best?
also ill have the electrical to back all this up
this will be a daily set up no comps or nothin
you dont tune a sealed box. the port is what tunes the box.
go to the car show tomorrow in denver and see some systems and ask around there. there will be some good info that you can gather
o forsure thanks! how many square inches and how wide should the port be for 32hz?
Yes you do... it's called QTC
OP. The alpines will be fine ran off the AQ3500. I had some 10's that took my SAZ3K like some champs //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Don't confuse him. Yes technically you build a sealed enclosure to have a certain F3 (the frequency where the output has dropped 3db) but it's not nearly as important getting it right as it is for a ported enclosure.
hockeytoker
hockeytoker
Highlands Ranch, CO
mcsoul
