2 12.1 perfects + 2 Sony DVC subs...how to wire?
31337hxr
okay guys, right now this is my current setup and is wire in mono/parallel:
(2) Infinity Perfects 12.1 @ 2ohm load -> JBL BP600.1
Each sub is getting 300watts RMS @ 2 ohm.
I want to add another two 12" Sony subwoofers into this amp. However, they are DVC and each subwoofer has a 2-ohm load by itself. The perfects have a 4 ohm load by itself.
How would one go about wiring this?
thanks guys!
854
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
976
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
31337hxr
31337hxr
Los Angeles
Mark_ab
    May 31, 2024
    May 24, 2024
