2-10's vs 1-12in Sub
Darius2004
Hello, I've been reading the forum for a while a just joined. I searched but couldn't find any solid answers to my question.
My system consist of:
Nakamichi Head Unit
PolkAudio db6500 seperates [FRONT]
PolkAudio db650 2-way with Xover [REAR]
2 - Kicker KX600.4 amps [TRUNK]
1 - Kicker C12 Free-Air 12" Sub
2 - Xtant A1040 10" subs in a Q-Logic Box
Right now I have the Kicker sub installed but I just bought the xtant subs and the Qlogic box. I'm worried that I may lose some depth going with the smaller speaker but I've been told that 2-10's will hit harder and cleaner than 1-12
Could you guys please lend your expert advise?
PS - One Kicker Amp is power the cabin speakers and the other will power the 2 subs.
Any and all help is appreciated. Thanks in advance.
cleaner has nothing to do with it, it is really a point of do you want more volume ? if you not that worried about blowing the doors off the single 12 is fine
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
935
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
228
553
Darius2004
Darius2004
California
Darius2004
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
